7 set 2010, 02:57 GMT-4
if yu fix a boundary, you say u=0 v=0 ... so you cannot then apply a prescribed displacement that is u=disx, v=disy ... if disx and disy are different from "0".
remove the fixed at the end you put only a prescribed displacement and it should solve correctly.
Basically "fixed means" prescribed displacement all = "0"
If you are afraid your prescribed displacement will overstress the items in certain directions, apply a moment, check the ST doc (3.5a) or have a look at the example in the Model Exhange
7 set 2010, 13:31 GMT-4
Dear Ms Momeni
may you explain more! you mean the boundary moves by applying the stress?
Dear Ms Momeni
7 set 2010, 13:56 GMT-4
Thanks for your response. It solved my problem.
8 set 2010, 01:08 GMT-4
your question is slightly short, but if I got you right, yes, basically stress times strain is the Young modulus. In linear thory the Young modulus is generally considered as a constant so if you apply some stress you will get a displacement (for a fixed-free or free free object), just as if you imply a relative displacement on a fixed free object you will get a resulting stress, no ?
2 mar 2012, 09:02 GMT-5
I was wondering if you actually get the beam to buckle simply by applying the displacement.
Is the applied displacement prescribed in step-by-step mode from 0 ? How about from high displacement?
Doni
Doni
2 mar 2012, 10:11 GMT-5
for large displacements, turn on the (now since 4.2a in the solver node) geometrical non-linearitites
10 years ago
3 mar 2015, 08:27 GMT-5
I am trying to include geometric nonlinearities in my model but when I go to the study setting I just get an empty windows.
Why I don't have the possibility of checking "include geometric nonlinearities"?
