Finding the boundary number with the Comsol Java API
Hi everyone,
I am using the Java API with Comsol and I really like it's abilities overall. I build a block first, so there are six boundaries, later I want to set boundary #1(the first index of boundary) and #6(the last index of boundary) as periodic boundaries. However, the index of boundary changes when I add ellipsoids in the block. Is there a way to find the number of last index of boundaries or do you have other suggestion to solve my problem? The code like this:
model.physics("ec").feature("pc1").selection().set(new int[]{1, 54}); // when I add two ellipsoids in the block, the number of last index of boundary changes to 54.
The problem is that IDs of the boundaries – 1, 54 – often change as result of geometry changes. I guess there should be a way to get the IDs through API at runtime, but cannot understand how exactly from reading APIReferenceManual. Did anyone solve such problems? If possible, please write a example code.
Thanks in advance for your help,
Zijiang
0 Replies Last Post 17 ott 2015, 18:10 GMT-4
Hello Zijiang Yang
