Flow between vibrating plates
Posted 22 ott 2015, 14:58 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD) 0 Replies
Brief intro about my project:
Two asymmetrically walls, create a channel that can rapidly open and close. Water rushes into the channel when it expands and is forced out when it contracts.
I am trying to vibrate two walls up and down in fluid structure interaction by defining
solid mechanics->prescribed displacement and then i assigned two prescribed displacement values for both up and down wall.
But when i try to run my model i get error saying maximum number of newton iteration reached and non linearity can not be solved.The relative error is greater than the relative tolerance.
Could you please help me here?
Hello Nisarg Vashi
