Problem in solving multiple parameter value problem on MAC
I'm working on a MEMS model both on a MAC and on a computer that operates with Windows XP.
The problem appears on the MAC when a try to make a parameter value sweep on Solver parameters using more than two ranges of parameter values. The error window that pops up says "Parameter list must be strictly monotone".
The issue is that the list i use is strictly monotone . Also is been made using the "edit..." button in "Solver Parameters" so is not possible to have any typing error (and tit doesn't ).
The most weird thing is that the same model runs fine on the PC.
Thanks for your help
Dimitrios
0 Replies Last Post 14 set 2010, 14:53 GMT-4
Hello Dimitrios Grevenitis
