Complex acoustic pressure?
I have been working with several acoustic simulations with very good success, but it would be helpful if I had the option to view/export complex data. I am working with a frequency domain analysis, and it is my understanding that frequency domain models are naturally solved using complex numbers. Is there any chance of accessing the complex pressure solution (all I have right now is the real component)?
Matt
2 Replies Last Post 23 ago 2011, 09:24 GMT-4
Hello Matt Donarski
Posted: 1 decade ago 13 apr 2011, 15:10 GMT-4
Hi Matt,,
I now have the same issue. Do you solve the problem?
Hi Matt,, I now have the same issue. Do you solve the problem?
Posted: 1 decade ago 23 ago 2011, 09:24 GMT-4
Hey,
I work with COMSOL Multiphysics 4.1.
To get complex pressure values you can go to "Model builder" window and then follow the path: Results>derived values>point probe expression (this last part may be different for you) and then press the evaluation button in the "settings" window.
Hope it help you out,
Alireza
Hey, I work with COMSOL Multiphysics 4.1. To get complex pressure values you can go to "Model builder" window and then follow the path: Results>derived values>point probe expression (this last part may be different for you) and then press the evaluation button in the "settings" window. Hope it help you out, Alireza
