Simple heat exchanger model error
Posted 11 nov 2015, 06:49 GMT-5 Fluid & Heat, Heat Transfer & Phase Change, Geometry, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.1 5 Replies
Hi everyone,
I'm working on a heat transfer problem and could use some help. It concerns a large horizontal pipe containing an elongated u-shaped pipe (the 'loop'). The pipe contains air and the loop contains water. The water inside the u-shaped pipe is flowing and is laminar. The air in the larger pipe is initially at rest. There is heat being produced inside the u-shape. So heat is being transported from the loop through the pipe by convection and out of the model (using the external natural convection option inside the heat flux node). I'm interested in the steady state temperature in both pipe and u-shaped pipe.
Initially I started working on a simpler model which only contained 2 cylinders (ie. I used a cylinder instead of the loop). This model worked perfectly, but when I switched the smaller cylinder for the loop I started getting errors.
1. The direct solver gave the error of a singular matrix
2. the iterative solver returned a error message saying it ran into an undefined value.
I was wondering if these errors can be caused by poor meshing, since my boundary conditions are exactly the same for the working model and the non working model? Any help on solving my problem would be greatly appreciated!
5 Replies Last Post 31 mag 2017, 07:18 GMT-4
