21 set 2010, 08:43 GMT-4
Hi Attila,
best prepare a text file containing rows of data (T and eta(T) for viscosity) and then select Options->Functions...
There you define a new function using "Interpolate form File". Read in your viscosity data and use the function
as the gas property in the domain settings. The density does not need to be read from a file, because COMSOL
can calculate it from the ideal gas law (check box in domain settings).
Markus
Hi Attila,
Markus
21 set 2010, 09:07 GMT-4
Thank you Markus,
Your recomendation solved my problem.
Thank you Markus,
9 years ago
23 mag 2016, 08:12 GMT-4
I am experiencing another problem when I use Comsol 5.2. Comsol does not understand eta(T) as temperature dependent viscosity. Should I use another syntax rule. I am defining an interpolation function giving the eta values at different temperatures, but I cannot get COMSOL understand it. How should I solve this problem?
8 years ago
6 giu 2017, 11:24 GMT-4
Hi. Have you solved your problem?
[QUOTE]
[/QUOTE]
