Simulation of magnets to get magnetic flux density
Hello!
I am new to COMSOL.
I have done the geometry of two magnets in the file attach.
Then I start a stationary study.
How to get the result of the magnetic flux density?
If possible, how to make the component (magnets including the direction of the magnetic flux) in COMSOL look like the graph attach?
2 Replies Last Post 2 dic 2015, 07:13 GMT-5
Posted: 9 years ago 2 dic 2015, 01:55 GMT-5
have you checked carefully the Application library permanent magnet model, I believe everything is carefully explained therein
Hi have you checked carefully the Application library permanent magnet model, I believe everything is carefully explained therein -- Good luck Ivar
Posted: 9 years ago 2 dic 2015, 07:13 GMT-5
I have successfully done the tutorial.
I have tried to modify the geometry and finally the results cannot display the plots for the error occurs at arrow volume. It is said that the data cannot cover for more than one sector. I feel confused about it.
(1) is the original file and (2) is the file I have modified.
Thank you!!!
I have successfully done the tutorial. I have tried to modify the geometry and finally the results cannot display the plots for the error occurs at arrow volume. It is said that the data cannot cover for more than one sector. I feel confused about it. (1) is the original file and (2) is the file I have modified. Thank you!!!
