how to calculate an expression for multiple values
HI,
I am currently working with the classical PDE mode: Helmholtz equation. I've already obtained some values but now I am interested in manipulating these results. What I want to do is to calculate the following expression:
abs(u)*cos(arg(u)-2*pi*frec*time)
for different values of the "time" variable.
The other terms of the expression mean:
abs(u)= absolute value of the dependent variable (of the PDE system)
arg(u) =phase angle of the dependent variable (of the PDE system)
pi and frec constant values defined in "global definitions" tab.
I know that it is possible to do it manually (defining the expression for a specific value of "time" and plotting it) but the point is I need to obtain at least 300 images (in other words, I need to calculate the expression for 300 different values of the variable "time").
I do not know how to use the Comsol interface to set up a loop that allows me to obtain (and save) the 300 images. I've been also trying to manipulate the script in Matlab (just because it is easier to define loops) but I have some problems with saving and plotting images.
The problems are:
1) I am not able to plot any figure because the mphplot function does not work. When I use it, I always obtain the same problem:
"C\comsol40a\mli\mphplot.p" not recognizable as a P-file
2) I am also not able to export the image using the export function
model.result.export('img1').set('pngfilename', 'C:\\Documents and Settings\\Usuario\\Desktop\\resolution\\picture.png');
In this case Matlab does not show any error but it does not create the "picture.png" file.
I am working with the latest Comsol version 4.0a and Matlab 7.4.0 (R2007a).
I would strongly appreciate any idea or tip because I am really stuck on it.
Thank you very much
Cristina
1 Reply Last Post 21 dic 2010, 06:55 GMT-5
Hello Dejan Grabovickic
Posted: 1 decade ago 21 dic 2010, 06:55 GMT-5
Did you solve it?
I would like to do the same with three different plots at 4 interpolated times.
maybe it is easier to plot whatever you want in a figure then use the matlab-function saveas(handle,'dir/filename.png')
Did you solve it? I would like to do the same with three different plots at 4 interpolated times. maybe it is easier to plot whatever you want in a figure then use the matlab-function saveas(handle,'dir/filename.png')
