Sven Friedel
COMSOL Employee
9 years ago
16 dic 2015, 03:12 GMT-5
Dear Mozghan,
for the geometry you describe (a thin layer embedded), COMSOL has a variety of built-in tools, such as mapped meshes, domain dependent mesh sizes or special thin layer physics features. It might not be necessary to define the mesh size explicitly as a funtion of (x,y,z). That said, in the very rare case that this should be necessary, the adaptive mesher could be tweaked to do it, but before I recommend that way, please describe in more detail what you would like to do, or ideally send your file.
Sven Friedel
Dear Mozghan,
Sven Friedel
9 years ago
16 dic 2015, 11:00 GMT-5
Dear Mozghan,
Sven Friedel
Dear Sven
Thank you very much for your reply. Attached, please find my file.
the thin layer between the upper and bottom is a metal, 100 nm thickness. the wavelength is 3 mm. because the middle layer is a metal, the mesh size should be equal to (Skin depth)/ 10. So I should calculate the skin depth and the skin depth is a function of some parameters. afterwards, I will use the skin depth as my mesh size.
Thank you in advance for your reply
Best Regards
Mozhgan Hayati
[QUOTE]
Dear Mozghan,
Sven Friedel
[/QUOTE]
Dear Sven
Best Regards
Mozhgan Hayati
