doing simulations with coeff of thermal expansion using only the solid mechanics module
Posted 22 dic 2015, 05:41 GMT-5 Structural Mechanics 0 Replies
I am trying to perform sims with CTE (alpha's) in the solid mechanics module, but without the structural mechanics module (which supports CTE). I tested a demo version of the structural mechanics module but I did not get a budget to upgrade; I have an education in electronics & signal integrity, but not mechanics
I am trying to work around this. Comsol does not support body (volume) strains so I cannot simply distribute three orthogonal strains alpha*(T-Tref) through the material volume. However, for elastic bodies the strain-stress relation is easily inverted and one can distribute three orthogonal body forces -(E*alpha*(T-Tref)/(1-2*v), where E and v are the E-modulus and the poisson ratio, resp - assuming isotropic materials, more complicated problems like temperature dependent parameters and/or anisotropic materials should be possible.
The study steps involve a thermal followed by a mechanic step, the input in the 2nd is the temperature.
Based on the temperature we distribute body forces as stated above.
But maybe I miss something in my approach, I have not actually build a model and I was hoping to find something on the forum, which I did not ... unless I missed it
Any suggestion of comments on my approach are welcome
Hello Jan Vercammen
