Nagi Elabbasi
Facebook Reality Labs
9 years ago
28 dic 2015, 08:47 GMT-5
Dear Hari,
There are several ways to do that. One way involves solving the frequency domain problem at two frequencies F1 and F2, for a unit load (Pa=Pb=1). Then, in post-processing, multiply each solution by its load magnitude and add them up.
Nagi Elabbasi
Veryst Engineering
Dear Hari,
Nagi Elabbasi
Veryst Engineering
9 years ago
28 dic 2015, 21:54 GMT-5
Dear Nagi,
Thank you so much for your suggestion.
I have tried it on my model. But I have some questions.
-By adding in post processing do you mean join the two solution sets by adding them with sufficient weights? I went ahead with this method and it worked to a certain extent, which brings me to the second question.
-In the above, why is it that I cant get a far field polar plot when I use the data set as the join of solutions?
-Is there any other way to solve the original problem(You said there were a number of methods).
I would be extremely grateful if you have any suggestions. Meanwhile, I would work on my problem, and post here if I come up with useful solutions.
Thanks!
Dear Nagi,
Thanks!
9 years ago
30 dic 2015, 04:04 GMT-5
Just wanted to add something here.
I got another way to get the solution. So what i did was do a parametric sweep in the frequency domain study, with specific combinations of parameters. The parameters were the frequencies(F1 and F2) and the corresponding intensities. Once that was done, I did a simple join of the two solution sets by taking a sum and I got similar (almost identical) results!
Still cant plot a combined polar plot, but I could get the SPL polar plots for different frequencies, and plot them on the same graph.
Thanks!
Thanks!
Edgar J. Kaiser
Certified Consultant
9 years ago
30 dic 2015, 05:43 GMT-5
Hari,
which meaning would a combined far field plot for two (or more) frequencies have? There is no well defined phase relationship for two different frequencies in the far field. From a practical standpoint: have you ever seen combined far field plots of any antenna for more than one frequency or a frequency band? I haven't.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hari,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
9 years ago
30 dic 2015, 06:44 GMT-5
Hi Edgar,
Thank you for your response.
I don't think I made my point clear enough. What I have as a point source is a bubble that oscillates in an acoustic field, scattering a pulse of a frequency. This bubble gives out scattered waves with a combination of frequencies. I performed a fourier analysis and isolated the dominant frequencies. Now I want to treat the bubble as a point source emitting acoustic radiation at those frequencies.
So what I am thinking is
-shouldn't the far field polar plots reflect the effects of all the dominant frequencies?
-in order to do that, I combined the solutions from the different parameters of the parametric sweep, and tried making the far field plot. I think I am wrong with this second logic.
Please correct me if I am wrong in any of the steps above. Any help from you would be much appreciated!
thanks!
Hi Edgar,
thanks!
