Exporting surface pressure data
Posted 4 gen 2016, 08:19 GMT-5 Acoustics & Vibrations, Results & Visualization Version 5.0 0 Replies
I'm solving a scattering problem using the COMSOL acoustic module .
My solver solves for several frequencies and several incident wave angles using parametric sweep.
In order to post-process my data I need to export the pressure data from the scaterrer, and I need the pressure data from all the points on the surfuce (like what the plot node does), so using probes is not reasonable because i would have to use thousands of them.
Is there a way to automatically export the surfuce data for each parmeter value in the parametric sweep?
I have approximatly 2000 parmeter values so doing it manualy is not an option.
thanks for your help!
Hello Amir Musicant
