machines fed with voltage source. Error on convergence
Hi everyone! Recently im using comsol to model an induction machine in 2D. The machine is supposed to be fed with voltage source. First i use global equations to calculate the stator phase currents, then the results are divided by the area hence the current density is derived. However when i feed the stator with this current density and run the machine in a transient mode an error came out saying that 'nonlinear solver didnt converge. Maximum number of Newton iterations reached. Last time isnt converged'. I guess something went wrong with the global equation on current density calculation? Can you guys help me? thank you!
0 Replies Last Post 21 gen 2016, 08:49 GMT-5
Hello Zhi Xu
