Jeff Hiller
COMSOL Employee
8 years ago
9 mar 2016, 09:44 GMT-5
Yes, just use a rectangular function to define your heat source: Definitions>Functions>Rectangle.
Edit: I am not sure if that feature already existed in version 4.3. If not, you can get something similar by taking the product of two smoothed Heaviside step functions, etc.
8 years ago
9 mar 2016, 09:48 GMT-5
Hey Jeff,
But how do I make it start when the temperature reaches the desired value? I can definitely define a rectangular step function as a function of time. But I need the temperature condition.
Paul
Hey Jeff,
Paul
Jeff Hiller
COMSOL Employee
8 years ago
9 mar 2016, 09:50 GMT-5
I had not realized you did not know in advance how long your up time needs to be.
Instead you can use the concept of Events. See this link:
www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
Instead you can use the concept of Events. See this link: http://www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
8 years ago
9 mar 2016, 09:56 GMT-5
Hey Jeff,
Thanks for the help. I was thinking about events. But an event would give me a temperature dependence and that's all. I can have for example an event that has 0 until the temperature is reached. Then 1 when the temperature is reached. How do I make it back to 0 after a certain time?
Is it me, or I didn't see this information in the thread you have just provided (I know it from before)? And can I also implement time conditions in the events?
Paul
Hey Jeff,
Paul
Walter Frei
COMSOL Employee
8 years ago
9 mar 2016, 10:59 GMT-5
Dear Paul,
You can indeed expand upon the approach outlined here:
and modify as demonstrated in the attached file.
Note these features:
- An additional ODE for a variable "HeaterOnTime" that simply integrates "1" over time, thereby keeping track of time since any event at which HeaterOnTime is set to zero.
- An indicator state variable called "On_Time" that goes from negative to positive after a specified time.
- Implicit Event 1, that triggers when the temperature gets too low, and sets HeaterOnTime = 0
- Implicit event 2, that triggers based in the On_Time > 0 which turns off the heater.
Hopefully this is all fairly self-explanatory from here on. Please note that this file is created in version 5.2.
Best Regards,
Dear Paul,
Best Regards,
8 years ago
9 mar 2016, 16:00 GMT-5
Dear Walter,
Thank you very much! I don't have 5.2, but I will install it for this and I will write back if I encounter any problems.
Best Regards,
Paul
Dear Walter,
Best Regards,
Paul
8 years ago
10 mar 2016, 07:58 GMT-5
Dear Walter,
Thank you very much. It works as it should.
Paul
Dear Walter,
Paul
