Using functions in geometry parameters
Hi, I have defined functions (either globally, or in component) which I then wanted to use in geometry parameters like position. Comsol sais 'unknown function or operator'. How can I do this? A simplified example is attached.
Thank you
Daniel
1 Reply Last Post 15 giu 2016, 10:26 GMT-4
Posted: 9 years ago 15 giu 2016, 10:26 GMT-4
The geometry can only depend on parameters, not on functions. But parameters can be very general expressions of other parameters.
The difference between a parameter and a function is that the parameter is fixed within a certain study step, whereas a function can have any type of dependence on time, coordinates, results, etc. This is why it is not possible to let a function change the geometry.
Henrik
Hi, The geometry can only depend on parameters, not on functions. But parameters can be very general expressions of other parameters. The difference between a parameter and a function is that the parameter is fixed within a certain study step, whereas a function can have any type of dependence on time, coordinates, results, etc. This is why it is not possible to let a function change the geometry. Regards, Henrik
