Inter-study comparison capabilities?
I'd like to compare results from two studies I have set up, but have not had any luck getting COMSOL to perform operations like finding the difference in temperature field between two separate studies. I could export the results but I'd like to use the visualization functionality in COMSOL to show a differenced surface. Has anyone had any luck with this?
Thanks.
1 Reply Last Post 14 gen 2011, 06:58 GMT-5
Posted: 1 decade ago 14 gen 2011, 06:58 GMT-5
You would need to have them as two models in the same file,. Ten I believe you could plot a T1t - T2t with T1 in one model and T2 in another
Hi You would need to have them as two models in the same file,. Ten I believe you could plot a T1t - T2t with T1 in one model and T2 in another -- Good luck Ivar
