IntVolume Parameter in MatLab
Posted 20 feb 2018, 09:52 GMT-5 RF & Microwave Engineering Version 5.3 0 Replies
Is it possible to add the IntVolume expression parameters with a variables outside of the model? I want to calculate the coupling coefficient using a data from two different runs. I assigned the first data to a variable and tried to use it as a parameter for IntVolume function together with a second data but I am not sure about the syntax.
Ez1=mpheval(model,'emw.Ez');
model.result.numerical.create('int2', 'IntVolume'); model.result.numerical('int2').set('expr', 'emw.Ez'*Ez1);
Hello bamee
