Cut point 3D in the material frame
Posted 7 apr 2018, 02:40 GMT-4 Structural & Acoustics Version 5.2a 0 Replies
The below post is related to an archived discussion
There was a thread dated to 3 years ago about a cut point 3d which could not be attached to the material. I had the same issue when I was to plot the deformation of a specific point in an FSI simulation done in 5.2a.
The problem is that when you define a 3d cut point in a deforming solid, it will give you the result as long as the cut point is with in the solid domain. When the deformation is large enough that the cutpoint is not in the solid domain, the results would not be reported by Comsol.
As not a clear solution was proposed in the thread, I'd like to share that how you can make your 3D thread is attached to the material point.
The solution is that you need to define a new Base Date Set (Results>More Date Sets>Based Data Sets>Solution) and then select Material(X,Y,Z) as the frame. After that, you need to select this data set when are defining your 3D Cutpoint. By doing this you can be sure that the cutpoint will stay in the solid domain.
I hope it helps.
Best Hamed
Hello Hamed Keramati
