Anisotropic and B-H Curve
Posted 14 giu 2011, 08:30 GMT-4 Low-Frequency Electromagnetics 1 Reply
I simulate simple choke in 2D Time domain. I faced a problem where I need to apply nonlinear magnetic material with different B-H Curves in different directions.
I don't see such option. Is it even possible?
I see there is possibility to apply anisotropic MUR Curves. But even if I compute my model for isotropic MUR Curve calculated from B-H Curve I don't obtain the same results. Moreover I can't see any linearity then (like harmonics in the current waveforms). I've tried different methods of MUR Curve's extrapolation and interpolation but result is always similar.
In Ampere's Law branch as 'Constitutive relation' I select 'Relative permeability' -> 'From material'. In the 'Material Contents' I see that relative permeability is described by 'MUR(normB[1/T])'.
I would be grateful for any hint,
Przemek
Hello Przemek Kluska
