Undefined variable error message
Posted 29 ago 2018, 01:38 GMT-4 Electromagnetics, Electromagnetic Heating, Low-Frequency Electromagnetics Version 5.2 3 Replies
Hi, I am new to comsol.I have created a geometry which has 1[cm] width ,0.05cm depth and 0.5 cm height nickel alloy block on which there is a platinum strip of widht,0.05[cm].depth,0.005[cm],height,0.5[cm] to study the Joule heating due to current flow through platinum strip. On computing it shows the following error message: 'Undefined variable. -Variable:material.sigma13 -Geometry:geom1 -Domain:1-2 Failed to evaluate variable. -Variable:comp1.ec.sigmaaxz -Defined as:material.sigma13 Failed to evaluate variable. -Variable:comp1.ec.Jix -Defined as:(comp1.ec.Ezcomp1.ec.sigma Failed to evaluate variable. -Variable:comp1.ec.Jx -Defined as:comp1.ec.Jix Failed to evaluate expression. -Expression:d(((comp1.ec.Jxtest(comp1.V> Failed to evaluate Jacobian of expression. -Expression:((comp1.ec.Jx*(comp1.Vx)+
Please help me to find out what the error means and what should I do to compute the program.
