Cluster seems to run perfectly and outputs a file named test2out.mph but no results are shown
So i'm running my comsol 4.0a cluster from the command line with the bash script:
#!/bin/bash
#PBS -N comsol
#PBS -l nodes=5:ppn=8
cd /home/higginsb/comsol/
/share/apps/comsol40a/bin/comsol -nn 5 mpd boot -v -r ssh -f $PBS_NODEFILE
/share/apps/comsol40a/bin/comsol mpd trace
/share/apps/comsol40a/bin/comsol -nn 5 -np 8 batch -inputfile /home/higginsb/comsol/test2.mph -outputfile /home/higginsb/comsol/test2out.mph -batchlog b.log
/share/apps/comsol40a/bin/comsol mod all exit
everything seems to run perfect and i can monitor the cluster as its distributes the model across the nodes, but when it's done and i open the output file I get no results. I really can't figure out what is going on and i'm sure i'm just over looking something small but i've been at it for about 4 months now and can't find what is going wrong.
Some one please help me!!
Cheers!
Ben
3 Replies Last Post 19 ago 2011, 04:15 GMT-4
Posted: 1 decade ago 18 ago 2011, 04:54 GMT-4
I don't see anything wrong with your bash file except the last line that should be
/share/apps/comsol40a/bin/comsol mpd allexit
Alain Glière
Hi, I don't see anything wrong with your bash file except the last line that should be /share/apps/comsol40a/bin/comsol mpd allexit Best regards, Alain Glière
Posted: 1 decade ago 18 ago 2011, 13:32 GMT-4
I don't know why that space showed up here, but its not like that in the script itself. Is there anything else i might need so be doing in the model file itself?
Posted: 1 decade ago 19 ago 2011, 04:15 GMT-4
In fact, you also had "mod" instead of "mpd" in that line. But I don't think it is the problem...
Maybe you could try to remove the -outputfile option in order to have comsol write the solution in the original file?
Once it works, please post some information on the performance improvement you get (which on my side is really disappointing ...)
Alain Glière
In fact, you also had "mod" instead of "mpd" in that line. But I don't think it is the problem... Maybe you could try to remove the -outputfile option in order to have comsol write the solution in the original file? Once it works, please post some information on the performance improvement you get (which on my side is really disappointing ...) Best regards, Alain Glière
