How can I extract the data from a defined variable?
So in my study i used parametric sweep and used this expression to calculate total deformation of the system: sum(withsol('sol2',dy,setind(t1,i),setval(t,1)),i,1,20) My problem is that i cannot find a method to tabulate the values, I can plot them and they look great. But i need these values in an excel sheet or something. Help please.
2 Replies Last Post 6 apr 2020, 07:36 GMT-4
Posted: 5 years ago 2 apr 2020, 11:20 GMT-4
Aziz,
you can make tables in Comsol with 'Derived Values' and copy and paste them into external software. Or you use 'Export' options to generate table files directly.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Aziz, you can make tables in Comsol with 'Derived Values' and copy and paste them into external software. Or you use 'Export' options to generate table files directly. Cheers Edgar
Posted: 5 years ago 6 apr 2020, 07:36 GMT-4
Thank you Edgar I didnt realized i can use the "Export" Option to tabulate plots. That solved my problem.
