Partial Slice Plot
When I make a slice plot of a small portion of the model, the multiple slices are big and block the view of the small portion I'm trying to inspect with the slices. Is there a way to crop the slices to improve visibility? Or to make half-plane slices? Or any other easy method to trim away parts of the cut planes that block visibility of the region of interest?
3 Replies Last Post 25 gen 2012, 16:10 GMT-5
Posted: 1 decade ago 25 gen 2012, 15:11 GMT-5
you have basically two ways to reduce the amount of data:
a) add a subnode to the the plot: a filter node and then some condition of the type dom = 1 ... or X<0.1 or any combination
b) derive a copy of your data set and add a selection subnode to reduce the number of entities and plot that
Hi you have basically two ways to reduce the amount of data: a) add a subnode to the the plot: a filter node and then some condition of the type dom = 1 ... or X
Posted: 1 decade ago 25 gen 2012, 15:26 GMT-5
Thanks. Works. A minor nit. The filter condition results in very ragged edges where the condition trims the planes. Is there a way to fix this?
Posted: 1 decade ago 25 gen 2012, 16:10 GMT-5
from my experience only with a finer mesh
Hi from my experience only with a finer mesh -- Good luck Ivar
