Error Message
Hi, I am new to COMSOL multiphysics and I encountered an error. I am following a tutorial to get familiar with the software. Even after following the instructions, I am getting an error message which I cannot decipher. I am attaching the message. I would greatly appreciate any kind of help. Thank you. Upasana
1 Reply Last Post 8 giu 2020, 09:47 GMT-4
Posted: 4 years ago 8 giu 2020, 09:47 GMT-4
As the error describes, you have an empty expression in the layers section of the sphere node. This might occur if you added a layer and then removed the expression in the layer without deleting it. Deleting the layer should fix this.
Cheers,
Alex
Hello, As the error describes, you have an empty expression in the layers section of the sphere node. This might occur if you added a layer and then removed the expression in the layer without deleting it. Deleting the layer should fix this. Cheers, Alex
