Moving Mesh - Can you see it before you compute?
I'm using COMSOL 4.0a. Whenever I apply a free tetrahedral mesh, I can see it on the structure immediately. However, now I need to use a moving mesh to combine the results of structure deflection and fluid flow. I cannot get the solver to compute without errors. Am I supposed to immediately see the original position of the moving mesh once I specify all of the parameters the same way I see the tetrahedral mesh?
Laura Barkett
The Miltec Corporation, Emerging Technologies
NASA, Nuclear Propulsion
4 Replies Last Post 29 mag 2012, 03:47 GMT-4
Posted: 1 decade ago 24 feb 2012, 15:07 GMT-5
First of all, if you have the possibility try to use a later version as v4.0 was eally not fully ironed out ;)
It's also more fun to have a more stable tool
This said, I do NOT believe you are supposed to see the mesh deform like that, as to get the propagation of the shape the solver must be in action, or have run. Then by default you do not see the (final) mesh in the result plots, best is to turn on Wireframe and possibly off quality: rendering/smoothing.
Then to see what happens, do not forget to turn on "plot whle solving" I hope it was lready there in v4.0
Hi First of all, if you have the possibility try to use a later version as v4.0 was eally not fully ironed out ;) It's also more fun to have a more stable tool This said, I do NOT believe you are supposed to see the mesh deform like that, as to get the propagation of the shape the solver must be in action, or have run. Then by default you do not see the (final) mesh in the result plots, best is to turn on Wireframe and possibly off quality: rendering/smoothing. Then to see what happens, do not forget to turn on "plot whle solving" I hope it was lready there in v4.0 -- Good luck Ivar
Ananiah Durai Sundararajan
Posted: 1 decade ago 28 mag 2012, 20:24 GMT-4
I find trouble locating the moving mesh interface, could you please help me find the tab
Hi, I find trouble locating the moving mesh interface, could you please help me find the tab
Posted: 1 decade ago 29 mag 2012, 02:16 GMT-4
it depends on the physics you apply, several have included the ALE in the combination of several individual "physics".
You can find the moving mesh and deformed geometry under the PDE node of the physics lists
Hi it depends on the physics you apply, several have included the ALE in the combination of several individual "physics". You can find the moving mesh and deformed geometry under the PDE node of the physics lists -- Good luck Ivar
Posted: 1 decade ago 29 mag 2012, 03:47 GMT-4
Thanks Ivar, I could able to locate under mathematics-PDE Interfaces-Deformed Mesh-Moving Mesh. Can you please advise me how to combine this moving mesh with Solid Mechanics and Electrostatic physics.
Thanks for your help
Thanks Ivar, I could able to locate under mathematics-PDE Interfaces-Deformed Mesh-Moving Mesh. Can you please advise me how to combine this moving mesh with Solid Mechanics and Electrostatic physics. Thanks for your help
