moving mesh
Posted 26 mar 2012, 11:29 GMT-4 Fluid & Heat Version 4.2a 0 Replies
Im trying to simulate the flow pattern of steel fluid in the Ladle in the casting in 2D ( the attached file is what i did) . But i encountered a problem which said that "Failed to find consistent initial values. Last time step is not converged."
i want to use moving mesh to show the drainage of ladle. i defined upper wall as an inlet and i set the inlet velocity to zero.
would you please help me to solve this problem.
thanks
Hello Ali Kohanzadehmaranlou
