13 apr 2012, 11:38 GMT-4
if the depth applies (not always the case), it's generally found in the main physics node
17 apr 2012, 12:24 GMT-4
Hello~
I'm new for the Comsol simulation, and have the similar question about the depth of 2D model.
May I ask what's the original value that Comsol set of the depth (at z-axis) for the 2D model? Also, where can I change the value in 3.5 version? Thank you so much!
Hello~
17 apr 2012, 14:21 GMT-4
in most cases (but not always, pls check carefully ;) the default depth is 1[m] which means that everything in 2D is "per meter".
Unfortnately, it's too long since I last used 3.5, I just cannot remember, try to check the doc (I usually index my pdf, then search for "depth")
17 apr 2012, 16:14 GMT-4
Hello~
In 3.5, it's in the subdomain physics setting.
[QUOTE]
Hello~
[/QUOTE]
