How to extrude an imported 2D .dxf file in COMSOL
Hello Everyone,
I have a generated 2d image which is converted to dxf file. It can be easily imported and recognizied all the edges and points. But I like to convert to 3d by extruding it. Is there any way to convert it to cylindrical cross section and rectangular cross section. I have attached the model. Any help please? Thank you!
2 Replies Last Post 6 mag 2021, 13:02 GMT-4
Posted: 4 years ago 5 mag 2021, 22:19 GMT-4
You've imported your 2D file into your 3D geometry. It is apparently a set of lines, without surfaces. And it is not actually "in" the workplane you then created afterward. I suggest you instead import your 2D file directly into the workplane of interest (the software will let you do that; try it.) You also need to form surfaces to extrude, or else you will extrude a frame, not a volume. I suggest you try that and see if you can figure out the rest. If not, see how far you can get and repost your model.
Posted: 4 years ago 6 mag 2021, 13:02 GMT-4
Thank you for your reply. You are correct it has to be 2d surface inorder to extrude which I ignored. I fix this issue by using SolidWorks CAD design.
