Segregated vs fully coupled approach in the frequency-domain perturbation step
Posted 1 giu 2012, 04:38 GMT-4 Low-Frequency Electromagnetics, Studies & Solvers, Structural Mechanics Version 4.2a 1 Reply
I’m dealing with a model involving the magnetic actuation of a MEMS structure.
Two physics are involved: Solid mechanics and Magnetic Fields.
The magnetic field is generated by a wire carrying a current I = Is +linper(Id) (Is = static component, Id = dynamic component).
The MEMS device is subjected, through its boundaries, to a magnetic force, activated by the “force calculation” feature in the Magnetic Fields physics.
I’ve performed a “Small signal analysis-Frequency domain” study and I’ve noticed a strange thing:
the frequency domain-perturbation step gives a “physical” result (non-zero displacement vs frequency) only if a fully-coupled approach is employed in the corresponding solver sequence.
If otherwise, the default setting (i.e. Segregated) is maintained, the displacement of the structure is zero for any frequency.
It seems that in this last case the dynamic component of the magnetic force is not considered.
Am I missing some setting (maybe in the solvers) ?
Any hint?
Thanks in advance for the answer.
Alessandro
Any hint?
Alessandro
1 Reply Last Post 1 giu 2012, 05:02 GMT-4
