interpolation function problem
Dear all,
I got an issue I need solve very quick but I don't how to maage that problem.
Using heat transfer module I built up a modell only containing conductive heat transport. I have a quite large, 310 km × 280 km × 160 km block, the model is time dependent. As initial temperature values I built up a T(x,y,z) file, with four columns (x,y,z,T). The import of this file (10 MB) works well, comsol immiadetaly recognizes, it's 3 dimensional data, but after clickin on solve I got always the same error message:
mod1/sol1
Failed to load interpolation function file.
I sucessfully solved problems on the same geometry with smaller data files (around 1 MB), but it seems comsol can't handle a data file containint more than 311.000 data points.
Questions:
-Is there any data file limit using interpolation functions?
-If not, what could be the problem?
-How to solve it?
Thanks for all,
Donat
1 Reply Last Post 8 giu 2012, 09:52 GMT-4
Posted: 1 decade ago 8 giu 2012, 09:52 GMT-4
for me you should contact "support" they are the only ones having the possibility to reply correctly
Hi for me you should contact "support" they are the only ones having the possibility to reply correctly -- Good luck Ivar
