8 feb 2010, 21:42 GMT-5
Did you get an answer? I would like to know the same thing.
Also, is there a way to control the length of the streamlines?
9 feb 2010, 12:22 GMT-5
Hey!
Yes, this is the answer I got. Just be careful that they did a mistake in the formula you have to write (of course is the spatial gradient when you are considering the shear stress).
Regarding streamlines and shear stress: I am not sure if I understand your
question. If you like to extract the shear stress from a streamline, use
Cross-section plot parameters->Line extrusion and plot
shear stress = eta_chns*du/dt
at this line.
Boundary integration: This feature can only be used on boundaries. If you
want to integrate over a certain line in a subdomain, you need to draw this
line at that location.
Regarding the length...there should be, I think I saw it...I'll check!
Hey!
at this line.
9 feb 2010, 14:12 GMT-5
OK:
So you calculated shear stress as eta_chns*du/dy , or eta_chns*dv/dx?
Where does this calculation get entered into.
Thank you so much for the help!
OK:
10 feb 2010, 07:50 GMT-5
You welcome! I perfectly know how painful is trying to use a complete unknown software!
So, regarding our talk:
Multiphysics --> Cross-Section Plot Parameters --> Line/Extrusion --> y-axis data --> and here you write the expression you need.
Of course if you want the magnitude of the shear stress, just calculate the different components and do the modulus.
Tell me if you have any question...of course I don't know if I'll be able to answer :)
10 feb 2010, 09:30 GMT-5
I just found that COMSOL is not exporting the data on the specified streamline, but on a line defined by points. I'll tell you something as soon as the support will reply to me.
J
J
17 feb 2010, 18:51 GMT-5
I think I solved the problem in the following way.
I went on plot parameters and used Particle Tracing Plot, that in this case is the same as Streamline since I'm in a steady case. Then inside Line Color I selected, for example, ux (du/dx). Then I exported the Current Plot.
It's an horrible way to export the data, but it works. But really...sucks!
