Flow in a channel with changing cross section
Posted 20 giu 2012, 04:53 GMT-4 Computational Fluid Dynamics (CFD), Studies & Solvers Version 4.2a 1 Reply
I want to simulate a simple flow through a channel with changing cross section. If I have just a rectangle there is no problem and I get the expected parabola velocity field. Then I want to change the cross section somewhere so that the velocity raises. If I change it only a little bit, there is no problem. But if I change it about 50% or I get always errors like this:
Failed to find a Solution for all parameters
even when using the minimum parameter step
So what is the problem here? Do I have to change some parameters in the solver settings that Comsol can solve this one? Because this problem shouldn't be that complicated to solve.
1 Reply Last Post 20 giu 2012, 15:45 GMT-4
