boundary condition for outlet
i have a small doubt regarding the otlet condition in fluid flow simulation.
if i have a outlet tangential velocity is not zero, can i use outlet condition directly,
or do i need to create a imaginary long section at the outlet where the flow can be assumed to be normal and then use the outlet condition,
2 Replies Last Post 11 lug 2012, 16:31 GMT-4
Posted: 1 decade ago 6 lug 2012, 03:37 GMT-4
if your velocity value is not a fixed value, only the direction, you could try to set up a normal velocity condition, turn on the "Preferencs - equation view" and check the constraints and weak condition COMSOL uses to get a "normal flow", then adapt this to impose an oblique flow.
At least this is my firsth thought, and I believe this should work, at least until someone can prove it will not ;).
Give it a try
Hi if your velocity value is not a fixed value, only the direction, you could try to set up a normal velocity condition, turn on the "Preferencs - equation view" and check the constraints and weak condition COMSOL uses to get a "normal flow", then adapt this to impose an oblique flow. At least this is my firsth thought, and I believe this should work, at least until someone can prove it will not ;). Give it a try -- Good luck Ivar
Posted: 1 decade ago 11 lug 2012, 16:31 GMT-4
Thanks Ivar,
I need to work with two phase models.
i have been working on this for weeks now. i am attaching just a test model for simplicity.
But i have been unable to get the results. please help me out. i need it desperately. thanks again
Thanks Ivar, I need to work with two phase models. i have been working on this for weeks now. i am attaching just a test model for simplicity. But i have been unable to get the results. please help me out. i need it desperately. thanks again
