How to change font size in the help of Comsol?
I am using Comsol Livelink for Matlab and I open the Comsol help from Matlab (using 'mphdoc' command).
The help browser that I open looks exactly like the help browser of Matlab and even give as 'reference' options the option to change Matlab settings.
My problem is that the font on this help browser is too small for me.
I tried whatever I can to change font size and manage to do it in all other parts of Matlab - including Matlab's own help browser. Alas, I didn't find a way to change font size in the Comsol help.
Can anyone help?
Alon
4 Replies Last Post 5 nov 2012, 04:08 GMT-5
Posted: 1 decade ago 10 ott 2012, 05:48 GMT-4
I am quite new to this forum.
However, I did expect that someone from the Comsol team will be able to answer this technical question...
Anyone with an idea? I am really struggling with this help browser.
Alon
Hi, I am quite new to this forum. However, I did expect that someone from the Comsol team will be able to answer this technical question... Anyone with an idea? I am really struggling with this help browser. Thanks, Alon
Posted: 1 decade ago 2 nov 2012, 19:46 GMT-4
This is exactly the question I was looking for an answer to.
It looks like the font in the style sheets is 8 pt, which is pretty small for old weak eyes.
This is exactly the question I was looking for an answer to. It looks like the font in the style sheets is 8 pt, which is pretty small for old weak eyes.
Posted: 1 decade ago 3 nov 2012, 07:40 GMT-4
just to make it clear: here on the Forum, we are mainly users as you (including myself), if you need specifical help and cannot get it here, try "support" the "official way", if you have a running maintenance
Hi just to make it clear: here on the Forum, we are mainly users as you (including myself), if you need specifical help and cannot get it here, try "support" the "official way", if you have a running maintenance -- Good luck Ivar
Posted: 1 decade ago 5 nov 2012, 04:08 GMT-5
Hi Alon,
I don't use the mphdoc function since I don't have access to those documents from Matlab, however what I would do directly on Matlab is:
mphdoc arg1
to get the HTML documentation associated to the function arg1, then simply press CTRL +
See, if you keep pressed CTRL and repetitively press the + (plus) button font size should increase.
Hope it helps!
Mattia
Hi Alon, I don't use the mphdoc function since I don't have access to those documents from Matlab, however what I would do directly on Matlab is: mphdoc arg1 to get the HTML documentation associated to the function arg1, then simply press CTRL + See, if you keep pressed CTRL and repetitively press the + (plus) button font size should increase. Hope it helps! Mattia
