CAD import Module has stopped working
tried to import solidworks file ( no solidworks in my computer)
then the import module crashed
following info is presented
COMSOL CAD IMPORT MODULE HAS STOPPED WORKING
Problem signature:
Problem Event Name: APPCRASH
Application Name: readsolidworks.exe
Application Version: 4.2.1.110
Application Timestamp: 4e84ba52
Fault Module Name: SpaACIS.dll
Fault Module Version: 21.0.3.11027
Fault Module Timestamp: 4d41c898
Exception Code: c0000005
Exception Offset: 000ae200
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 4105
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
2 Replies Last Post 22 ott 2012, 16:30 GMT-4
Posted: 1 decade ago 22 ott 2012, 14:02 GMT-4
if you have the correct CAD import module you can read Parasolid files *.X_T or .X_B, and those are easily saved from SW. I believe you need the Livelink to read hte *.sldprt files
Hi if you have the correct CAD import module you can read Parasolid files *.X_T or .X_B, and those are easily saved from SW. I believe you need the Livelink to read hte *.sldprt files -- Good luck Ivar
Posted: 1 decade ago 22 ott 2012, 16:30 GMT-4
Thx for reply ^^
I saved the file into X_T and successfully import the model
thank you very much!!!
Thx for reply ^^ I saved the file into X_T and successfully import the model thank you very much!!!
