Geometry Import
Hi all,
I am using the geometry tool in COMSOL to build several circles which tie in with some global parameters to easily modify on future studies. Is there a way to import the geometry and parameters together so I no longer have to keep building the geometry everytime I run a study and the imported geometry will be able to be modified when changing the parameters.
1 Reply Last Post 10 lug 2023, 12:25 GMT-4
Posted: 2 years ago 10 lug 2023, 12:25 GMT-4
I'm thinking you just might benefit from using one of the several LiveLink add-on interfacing products available. If you don't already know about those, see the links listed under "Interfacing Products," at https://www.comsol.com/products .
I'm thinking you just *might* benefit from using one of the several *LiveLink* add-on interfacing products available. If you don't already know about those, see the links listed under "Interfacing Products," at https://www.comsol.com/products .
