connecting CIR to MF physic
I'm a quite new Comsol user, and I have some questions.
I want to excite a coil (mf physic) with an electrical circuit (cir physic) in a 3 D model. I have put a boundary feed and ground conditions for the coil. The boundary feed is defined with a current (circuit) coil excitation.
The cir circuit is composed of a voltage sine source in serie with a resistance, capacitance and the external I Vs U device (with Coil voltage (mf/stdc) choose in the voltage list).
I compute with a time dependent solver, no problem of convergence but no coupling with the mf physic! I can just measure currents and voltages in cir circuit. Why?
I found in Comsol doc a sentence but I don't understand what I suppose to do to connect properly physics.
"Except for when coupling to a circuit terminal or circuit port, the current flow variable must be manually coupled back in the electrical circuit to the context of the voltage measurement"
I have only two way to connect my electrical circuit, with external I Vs U and external V Vs I, respectively with boudary feed current (circuit) and boundary feed voltage circuit, giving the possibility to fixe coil voltage or coil current in the external device. I try the 2 possibilities with no success.
I join a simple model to illustrate things,
I need help, someone know how to connect this ?
Thank you
Julien
2 Replies Last Post 22 nov 2012, 03:55 GMT-5
Andrea Ferrario COMSOL Employee
Posted: 1 decade ago 22 nov 2012, 03:38 GMT-5
Hello Julien,
The 3D Single Turn Coil Domain works more or less like a "local" version of the Magnetic and Electric Fields physics, so it is likewise not applicable in Time Dependent studies. It can be used in Stationary and Frequency studies only.
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Hello Julien, The 3D Single Turn Coil Domain works more or less like a "local" version of the Magnetic and Electric Fields physics, so it is likewise not applicable in Time Dependent studies. It can be used in Stationary and Frequency studies only. -- Andrea Ferrario Electromagnetics Group COMSOL AB
Posted: 1 decade ago 22 nov 2012, 03:55 GMT-5
Thank you for the quick response Andrea,
There is a tutorial model called inductor_in_circuit.mph where mf and cir are coupled together. I join the model
The difference is that the tutorial is in 2 D axy and mine in 3D.
If 3D is the problem, can I visualize current and voltage in function of time (1/freq) in frequency domain? I think not.
Julien
Thank you for the quick response Andrea, There is a tutorial model called inductor_in_circuit.mph where mf and cir are coupled together. I join the model The difference is that the tutorial is in 2 D axy and mine in 3D. If 3D is the problem, can I visualize current and voltage in function of time (1/freq) in frequency domain? I think not. Julien
