How to add unbalanced masses to a shaft?
Dear all,
I am working on the COMSOL case "Whirling of Uniform Shaft Under Gravity" (URL:https://www.comsol.com/model/whirling-of-uniform-shaft-under-gravity-43541).
I would like to add unbalanced masses to the shaft to see the effect on the behavior of the shaft.
I do not want to change the structure of the rotor. How can I add a tiny unbalanced mass to the shaft without changing the shaft structure?
Many thanks in advance.
2 Replies Last Post 29 feb 2024, 07:00 GMT-5
Frederik Wagner COMSOL Employee
Posted: 1 year ago 29 feb 2024, 06:59 GMT-5
Updated: 1 year ago 29 feb 2024, 07:00 GMT-5
I would suggest that you add the unbalance force directly as a co-rotating point load, e.g. , where , , and are the unbalance mass, eccentricity and rotational speed, respectively.
Frederik Wagner
COMSOL
I would suggest that you add the unbalance force directly as a co-rotating point load, e.g. F_y = m\,e\,\omega^2, where m, e, and \omega are the unbalance mass, eccentricity and rotational speed, respectively. Frederik Wagner COMSOL
Posted: 1 year ago 29 feb 2024, 07:00 GMT-5
Updated: 1 year ago 29 feb 2024, 07:04 GMT-5
Alternatively, you could add a Disk feature, having a radial offset and zero moment of inertia.
Henrik Sönnerlind
COMSOL
Alternatively, you could add a *Disk* feature, having a radial offset and zero moment of inertia.
