Cohesive Zone Modeling only mode I
I am modeling the connection of two objects using CZM (Cohesive Zone Modeling). I only want to utilize Mode I (tension) instead of Mixed Mode. Does anyone have any suggestions or tips?
Thank you.
3 Replies Last Post 26 apr 2024, 03:48 GMT-4
Posted: 6 months ago 24 apr 2024, 07:18 GMT-4
Updated: 6 months ago 24 apr 2024, 07:18 GMT-4
The built-in model is inherently mixed, so this is not trivial. You would probably have to do some equation based modeling.
However, it would be interesting to understand what behavior you want: Is it decohesion in tension while still undamaged in shear, independent of the level of the shear stress?
Henrik Sönnerlind
COMSOL
The built-in model is inherently mixed, so this is not trivial. You would probably have to do some equation based modeling. However, it would be interesting to understand what behavior you want: Is it decohesion in tension while still undamaged in shear, independent of the level of the shear stress?
Posted: 6 months ago 24 apr 2024, 08:46 GMT-4
Updated: 6 months ago 24 apr 2024, 08:51 GMT-4
Yes! I want my model is decohesion in tension while still undamaged in shear, independent of the level of the shear stress.
However, I'm not quite sure of the specific steps required to implement this. Could you provide guidance or assistance?
Thank you.
Yes! I want my model is decohesion in tension while still undamaged in shear, independent of the level of the shear stress. However, I'm not quite sure of the specific steps required to implement this. Could you provide guidance or assistance? Thank you.
Posted: 6 months ago 26 apr 2024, 03:48 GMT-4
I suggest that you contact support in order to get more detailed help in this case.
Henrik Sönnerlind
COMSOL
Reply
