automatic remeshing
Hello everybody,
I'm trying to use the automatic remeshing function of comsol with the ALE method. This allows to remesh the geometry according to a specific criterion.
My problem is that I would like to remesh my geometry not according to a quality mesh parameter but according to the time. Fo example, I would like to remesh my geometry every 0,1s of simulation. It seems impossible to define such a parameter because the only parameters available refer to mesh quality. I need the COMSOL keyword which gives the number of time intervalle in which I am (which correspond to the number of time that my geometry was remeshed).
Thank's for the help.
Julien
3 Replies Last Post 14 mag 2013, 01:50 GMT-4
Posted: 1 decade ago 6 mar 2013, 01:12 GMT-5
I believe its a Booelan expression whatever variable you put in is compared to the threshold value, so you could try a
0.1-mod(t[1/s],0.1) < 0.01
or something similar
Hi I believe its a Booelan expression whatever variable you put in is compared to the threshold value, so you could try a 0.1-mod(t[1/s],0.1) < 0.01 or something similar -- Good luck Ivar
Posted: 1 decade ago 6 mar 2013, 02:47 GMT-5
Thank's, I'll try that.
Julien
Thank's, I'll try that. Julien
Posted: 1 decade ago 14 mag 2013, 01:50 GMT-4
Hi Julien,
Have you figured out a way to do this? I tried the way that Ivar suggested but it did not work well. Since after the remeshing the program seems to start from the same time where it stops the variable 't' does not change throught the remeshing and Comsol will just stop the calculation.
Hi Julien, Have you figured out a way to do this? I tried the way that Ivar suggested but it did not work well. Since after the remeshing the program seems to start from the same time where it stops the variable 't' does not change throught the remeshing and Comsol will just stop the calculation.
