Multiple concentration step function
Posted 2 apr 2013, 12:55 GMT-4 Chemical Reaction Engineering Version 4.3a 19 Replies
Have a great day.
I am a new user of comsol 3.5 version, currently, I am working with chronoamperometry and I am trying to simulate that one using comsol by multiple concentration step functions. My quit time is 5s, at this quit time, the c=1 and then, after 5s, it step to c=0 with pulse width of 10s and then back to c=1 which has a pulse width of 5s. Currently, I am trying to utilize Heaviside function (flchs(time, 0.00001)) however, it doesn't give me a multiple steps.
I wonder if there are people out there who had encountered or done things that is similar or related to this problem and who is willing to share an idea.
Thank you.
Erwin
you need to mix in a modulo function mod(,) to get repetition (in V4 it's far easier now). Define it in the function node so you canplot it to check the shapes (or use matlab)
Thank you for the response. As of now, I don't have the V4, so, is mixing with modulo function when using V3.5a is the only possible way of getting repetition?
Thank you
Erwin
At least its the first one I would try, I believe this has been discussed earlier too on the Forum
I tried it already but, it doesn't work, it gives me a constant output current. Because the problem is all about stepping the concentration and the current is a function of concentration.
This is what I did,
heaviside: C1i+flc1hs(-5+t, 0.1)*(Ct-C1i), the 5 is the quit time where the conc=1=C1i and I want this function to drive it to zero conc, and back and forth width pulse width of 10s.
I am not sure with this modulo function because it is my first time to use this, C1i-flc1hs((-10+(mod(t,0.01))/time,0.1)*(Ct-C1i), the 10 here is the width of the pulse that is repeated. time=time normalizer
I used other equation that relate this to have the current as the output.
I am wondering if I am in the right track. Thank you for the comments and help.
Erwin
PS: I am using 2D axial symmetry for my model.
I am wondering if this will matter.
Thank you and have a wonderful day.
Erwin
2D-axi is a good way (if you model AND all loads are 2D axisymmetric) as it uses far less RAM and solves quickly allowing you to change rapidly BC and adapt the model interactively, until you are happy, then run a model with a fine mesh for final results
I always start 2D or 2D axi when possible, then in last resort I make a 3D model
Note in 2D axi displacement are either radial or transverse along the axis Z (and radial means in a projection radial for any angular direction phi)
For the function, you really should write it out in the function tab and plot it, as it's easy to miss something
C1+(C2+C1)*(sin(pi*t/T)>=0)
which flicks between 1 and 0 depending on whether sin is +ve or -ve.
The main problem is you can't really smooth it which may lead to convergence problems.
you could combine it with a smoothened step or rect operator in v4
I will try to use boolean.. Hope this will work..
have a great day
erwin
Thank you.
My problem is we don't have the v4 so I need to use mathematics to utilize v3.5a with this problem.. One thing that I need to consider is the relationship of the function that i am going to define using heaviside and modulo in relation to fick's second law of diffusion which is my basis of computing current.
Sincerely,
Erwin
I tried to set up the heaviside mixed with modulo functions but it doesn't work. I am trying to use this for periodic concentration step from c=1 to c=0 back and forth for around 10 times. In every concentration, there is a 10 seconds before it steps down or up to the next concentration. Right now, I am using v3.5a.
My another problem with comsol is that t doesn't recognize the concentration units.
Is anyone there has an idea and encounter related problems with this? also, how to set up of heaviside mixed with modulo functions?
Hope to hear from anyone.
Thank you.
Erwin
I tried to set up Heaviside mixed with modulo functions but it doesn't work. Do you have any idea on how to set up the mixed heaviside and modulo function?Thank you.
Erwin
well for the units, the functions require unitless arguments so you must "turn these off by [1/m] or [1/s] or whatever applies and then remultiply your function by 1[whatever units].
There shold be some old threads about 2-3 years ago now, that discussed this with examples (back in 3.5 and early 4. times ... modulo and Heavyside should realy work together I used to enter them into an analytical function to be able to plot them, I believe to remember thsi worked also so in v3.5 ;)
or debug the calls in Matlab, or Octave / Scilab or even Phyton, then prot them into COMSOl with a cut&paste (+ any naing correction)
Thank you for the prompt reply.
I have my heaviside mixed with modulo functions:
Cb-(flc1hs(10-mod(t, 0.1), 1)*(Cb+Ct)
Heaviside only:
Cb-flc1hs(10-t,0.1)*(Cb+Ct)
Cb-initial concentration which is 1
Ct-step concentration which I defined as:
Ct=Cb-sr*(t-10), where sr is the step rate=0.01
I just don't understand why I end up with sawtooth plot and the color of the concentration profile is blue which is instead to be red and only the boundary defined here is the one that is affected. Hope that you can give me your insights as to where on this functions I have mistaken that cause problems. My time for each pulse is 10 seconds.
Hope to hear from you.
Thank you Ivar.
Erwin
If I understand you correctly you want to turn the concentration between C1 and C2 on and off every T s. The easiest way I find is to use the boolean
I am dealing with a similar issue. I have an "Inflow" BC where C= 0.001 mol/m^3 for t:[0,1] and C = 0 mol/m^3 for t: [1,2] and this repeats over the time interval. But I have never been able to go beyond the first pulse. I have used finer meshes, intermediate time stepping and tried out different heaviside functions, but no luck. Has anybody encountered similar issues ? Is pulsing BC too difficult to handle ?
Many thanks,
Sanket
At the end of the first pulse I get the following error-"Reached error test failures-May have reached singularity". At this stage the concn is very very low like 10^-187 mol/m^3.
I think our problems maybe related. I ll post the solution if I manage to solve the problem.
PS: I am using a 2D axisymmetric model in COMSOL 4.3.
Best Luck,
Sanket
Have a great day. Thank you so much in advance. I am working with it also as of now.. I hope I can have it.
Erwin
I am going back to one of most basic things in the comsol, I am supposed to increase the mesh in exponential grid to generate 2-d dimensional grid. I am calculating current, but the result did not agree with the expected one which is based on the equation on the book. I check my model several times and there is no mistake on this matter. Do you have any idea on how to do this one in v3.5a?
Thank you.
Erwin
3.5 is old for me, but I believe you had a possibility with the dimension tab to set an equation (select a boundary or edge and apply a structured mesh with a given distribution equation for the mesh nodes, then mesh the full surface
