how to set the domain temperature?
In heat transfer in solid model I need to set the domain temperature as a constant value(such as T=300K) In all the computing process. Now I can only set the boundary temperature.Thanks.
1 Reply Last Post 6 apr 2013, 08:31 GMT-4
Posted: 1 decade ago 6 apr 2013, 08:31 GMT-4
Haiqun,
you can set all boundaries of the domain to 300K and the domain itself to an initial value of 300K. That should do the job.
Edgar J. Kaiser
www.emphys.com
Haiqun, you can set all boundaries of the domain to 300K and the domain itself to an initial value of 300K. That should do the job. -- Edgar J. Kaiser http://www.emphys.com
