Moving mesh 2D
I am trying to simulate the moving boundary for a 2D geometry.
I started with a simple 2D geometry where 1 boundary is moving in the x-direction and 1 boundary in y-direction, but because the boundaries are connected in one point, that point cannot move in x and y in the same time. For this reason i did a filet and the added boundary is moving in x and y.
My problem is that after specifying the velocities for which the boundaries are moving and hit compute, inverted mesh elements appears after 11 seconds. Even if I change the mesh quality the problem is not solved.
Mai I know why is behaving like this and what should I do in order to move the boundary further?
I attached the model for a better view.
7 Replies Last Post 17 mag 2013, 02:35 GMT-4
Posted: 1 decade ago 24 apr 2013, 17:05 GMT-4
I used to face similar problem. I found that changing the mesh smoothing from "Laplace" to "Hyperelastic" has helped me a lot. It has eliminated inverted meshes and enabled me to achieve higher mesh displacement. Also activate the "Mesh Smoothing Velocity". This is under " Normal Mesh Velocity" tab. It is unchecked by default.
Hope this works for you,
Sanket
Hi, I used to face similar problem. I found that changing the mesh smoothing from "Laplace" to "Hyperelastic" has helped me a lot. It has eliminated inverted meshes and enabled me to achieve higher mesh displacement. Also activate the "Mesh Smoothing Velocity". This is under " Normal Mesh Velocity" tab. It is unchecked by default. Hope this works for you, Sanket
Posted: 1 decade ago 25 apr 2013, 09:35 GMT-4
I tried what you suggested Sanket but I still have this problem.
Other hints from you or someone else will be much appreciated.
I tried what you suggested Sanket but I still have this problem. Other hints from you or someone else will be much appreciated.
Posted: 1 decade ago 25 apr 2013, 15:32 GMT-4
I assume you have already tried "automatic remeshing". I haven't had much luck with it. But you can give it a try nevertheless.
Posted: 1 decade ago 27 apr 2013, 11:32 GMT-4
If you mean to check the box automatic remeshing in the solver, yes i did this point.
Posted: 1 decade ago 29 apr 2013, 09:29 GMT-4
I am officially stuck at this point. Can I have some help ?
Best regards
I am officially stuck at this point. Can I have some help ? Best regards
Posted: 1 decade ago 3 mag 2013, 01:23 GMT-4
Does anyone have an idea about how should be done this moving boundary in a 2D geometry ?
Posted: 1 decade ago 17 mag 2013, 02:35 GMT-4
nobody?
nobody?
