Hello Fnu Mohammed Taqiuddin
Jeff Hiller
COMSOL Employee
9 years ago
4 dic 2015, 10:41 GMT-5
Hello Fnu,
The loft capability is available in the Design Module, see
www.comsol.com/design-module
Hello Fnu,
The loft capability is available in the Design Module, see http://www.comsol.com/design-module
8 years ago
30 set 2016, 06:09 GMT-4
hi,
I checked on the link you posted, and it says nothing about how to loft a surface to create a 3D object. Neither is any info available in the DesignModuleUsersGuide nor COMSOL_ReferenceManual nor webpage support/videos/etc
I know comsol CAD modeller is quite basic and its main goal is not to include all functions available in regular 3D CAD software, but definitely it should provide a proper help/guidance on the newest featured tools.
hi,
Edgar J. Kaiser
Certified Consultant
8 years ago
30 set 2016, 07:43 GMT-4
Oscar,
I don't know where you were looking. Here is the respective sentence in Jeff's link:
--citation
In addition to the geometric operations found in the CAD Import Module, you can also create lofted objects based on cross-sectional profiles ...
--citation end
In Comsol 5.2a you can add a loft feature to your geometry (you need the Design Module licence) and calling the help (press F1) opens the respective documentation.
Hope that helps.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Oscar,
--citation
--citation end
Hope that helps.
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
Jeff Hiller
COMSOL Employee
8 years ago
30 set 2016, 09:46 GMT-4
Hello Oscar,
Beside the sentence that Edgar pointed out above and the one following it, you will find a couple of pictures on the same webpage that illustrate the use of lofting with the Design Module. In the Design Module manual that you mention, the lofting capabilities are addressed in various locations, particularly starting on pages 17, 37 and 78 in version 5.2a of that document. I used Ctrl+F and queried for "loft" to find those pages quickly.
There is also a detailed example with step-by-step instructions on how to use the loft operation, entitled "Working with the Loft Operation" in the Introduction to Design Module manual. Check it out!
PS: The lofting operation is not documented in the COMSOL Multiphysics Reference Manual because that manual covers functionalities of the core COMSOL Multiphysics while the lofting capabilities are exclusive to the Design Module.
Hello Oscar,
