input displacement of deformed configuration-FSI
Fluid-structure-interaction(FSI) module has been used to simulate the movement of a spherical particle driven by Laminar fluid with time dependent.For further study, I need to construct a function, say f(x), with its origin at the particle center. That means the function varies with the movement of particle.
In order to make the function, I use the particle displacement u_solid as a variable to make a coordinator transformation, like f(x-u_soild). And then implement such function into a PDE module for the study. Of course, it can not work and comsol reminded me there is no initial value of u_soild, since it is a output. I think there should exist a input displacement for the automatic deformed-meshing calculation, and the input displacement may be hidden to the comsol user, even though the input value finally is equal to u_soild after the calculation.
Now I need the input displacement and implement it to make the function. But how can I realize it?By the way, it seems no other method to make such function in the FSI module itself. Any suggestion is appreciated.
0 Replies Last Post 28 giu 2014, 00:38 GMT-4
Hello Li Wan
