Implementing a two-temperature-model (electronic/lattice) for fast laser-excitation
I want to model a pulsed laser that hits a solid, excites electrons which "thermalize" then transferring their energy to the lattice (solid, atoms). I think most people do not use COMSOL for this purpose, but I want to, because I started with classical heat conduction and now want to setup my model in greater detail.
The two-temperature model is basically a model where you define two temperatures for electrons and atoms in a material respectively. This is necessary if you take into account that the electrons react much faster on an external excitation (femtosecond laser pulse [1E-15 s]) than the atoms.
The question is: how to realize this in COMSOL . In principal I would expect to be able to add and couple two heat transfer physics with two different dependent variables Te (electronic) and T (atoms) and custom material parameters (thermal conductivity, source terms). But how do I couple these?
Or would it be easier to go directly for custom PDEs and without predefined physics terminals?
Please help me here.
Henning Hollermann
16 Replies Last Post 14 feb 2018, 13:57 GMT-5
Posted: 1 decade ago 14 lug 2014, 07:18 GMT-4
Henning Hollermann
Dear Sir,
I am also trying similar problem. i found one thesis related this work. he used the phonon coupling factor.
please excuse me if i am wrong.
links: e-collection.library.ethz.ch/view/eth:8438
thanks
kiran
[QUOTE] Hello, I want to model a pulsed laser that hits a solid, excites electrons which "thermalize" then transferring their energy to the lattice (solid, atoms). I think most people do not use COMSOL for this purpose, but I want to, because I started with classical heat conduction and now want to setup my model in greater detail. The two-temperature model is basically a model where you define two temperatures for electrons and atoms in a material respectively. This is necessary if you take into account that the electrons react much faster on an external excitation (femtosecond laser pulse [1E-15 s]) than the atoms. The question is: how to realize this in COMSOL . In principal I would expect to be able to add and couple two heat transfer physics with two different dependent variables Te (electronic) and T (atoms) and custom material parameters (thermal conductivity, source terms). But how do I couple these? Or would it be easier to go directly for custom PDEs and without predefined physics terminals? Please help me here. Best regards, Henning Hollermann [/QUOTE] Dear Sir, I am also trying similar problem. i found one thesis related this work. he used the phonon coupling factor. please excuse me if i am wrong. links: http://e-collection.library.ethz.ch/view/eth:8438 thanks kiran
Posted: 10 years ago 16 apr 2015, 04:02 GMT-4
I am trying to solve a similar problem and I am using PDE (c) interface. Anyway, how did you try to solve it?
Thanks!
Thank you kiran. The thesis of Mr Dold was helpful to me understanding, how to introduce the heat input of the laser. I tried to follow the model of Verburg et al. (link.springer.com/article/10.1007%2Fs00339-013-7668-5), but had serious convergence problems with that.
I had to set the absolute tolerances for each dependend variable withing the time-dependent solver. Here is a little quote from the report I wrote about these issues which might be helpful to you.
However, I would put a large warning sign at this point. Before you try to do such complicated things, ask people how have done this before (with success). COMSOL may not even be the best choice here, since you may have to dig deeper than it is possible with this suite. Additionally, it happend more than once to me, that I got along some error messages, that weren't even my faults, but some internal COMSOL failures. And you could hardly distinguish these two. Be careful.
Meshing, tolerances and convergence
Meshing is very important for finite-element problems, as it influences convergence and the quality of the solution. For smaller time steps you have to chose a finer mesh to prevent unphysical oscillations of the solution in-between the nodes of the mesh, but you should keep the mesh as simple as possible as the computational complexity grows with the number and type of mesh elements.
Convergence is usually defined by the relative and the absolute tolerances. The smaller they are set, the more accurate the solution will probably be, but also the longer the calculation of each time step may take. If this tolerance criterion cannot be reached within a certain number of Newton iterations, the solver throws an error. To reach it anyway while maintaining a physically correct and accurate solution it is very important to set these values correctly. Sometimes it can be very hard to make a good compromise here.
Additionally, for better computational performance, the dependent variables are scaled so that their values are near to one. The tolerances are usually applied to the scaled variables. Although COMSOL tries to guess the scaling values, it fails especially for complex problems with equations of your own, as we deal with here. Therefore it is very important for the smooth convergence of the problem to manually choose the right scaling value for each variable. This is typically the highest order of magnitude you would expect the variable to reach during simulation.
At the end I got it running (although very unstable), but physical meaning...hm...
image-upload.de/file/WN2Ybq/1e5e6d146d.png
Henning
[QUOTE] Hi I am trying to solve a similar problem and I am using PDE (c) interface. Anyway, how did you try to solve it? Thanks! [/QUOTE] Thank you kiran. The thesis of Mr Dold was helpful to me understanding, how to introduce the heat input of the laser. I tried to follow the model of Verburg et al. (http://link.springer.com/article/10.1007%2Fs00339-013-7668-5), but had serious convergence problems with that. I had to set the absolute tolerances for each dependend variable withing the time-dependent solver. Here is a little quote from the report I wrote about these issues which might be helpful to you. However, I would put a large warning sign at this point. Before you try to do such complicated things, ask people how have done this before (with success). COMSOL may not even be the best choice here, since you may have to dig deeper than it is possible with this suite. Additionally, it happend more than once to me, that I got along some error messages, that weren't even my faults, but some internal COMSOL failures. And you could hardly distinguish these two. Be careful. [QUOTE] Meshing, tolerances and convergence Meshing is very important for finite-element problems, as it influences convergence and the quality of the solution. For smaller time steps you have to chose a finer mesh to prevent unphysical oscillations of the solution in-between the nodes of the mesh, but you should keep the mesh as simple as possible as the computational complexity grows with the number and type of mesh elements. Convergence is usually defined by the relative and the absolute tolerances. The smaller they are set, the more accurate the solution will probably be, but also the longer the calculation of each time step may take. If this tolerance criterion cannot be reached within a certain number of Newton iterations, the solver throws an error. To reach it anyway while maintaining a physically correct and accurate solution it is very important to set these values correctly. Sometimes it can be very hard to make a good compromise here. Additionally, for better computational performance, the dependent variables are scaled so that their values are near to one. The tolerances are usually applied to the scaled variables. Although COMSOL tries to guess the scaling values, it fails especially for complex problems with equations of your own, as we deal with here. Therefore it is very important for the smooth convergence of the problem to manually choose the right scaling value for each variable. This is typically the highest order of magnitude you would expect the variable to reach during simulation. [/QUOTE] At the end I got it running (although very unstable), but physical meaning...hm... http://image-upload.de/file/WN2Ybq/1e5e6d146d.png Best regards, Henning
Posted: 10 years ago 20 apr 2015, 03:24 GMT-4
I may add a few references, that may be used to tackle this problem:
Since the Verburg model yields (at least for me) a very unstable model, I would not recommend that as a start.
The thesis of Dold was already mentioned: dx.doi.org/10.3929/ethz-a-010114797
Also www.comsol.de/model/laser-heat...g-a-self-guided-tutorial-12317 may be useful to you.
You may have a look at the numerous papers there are for laser-induced damage in glass (SiO2), using a sub-bandgap high intense laser, e.g. Sun et al. www.opticsinfobase.org/oe/abstract.cfm?uri=oe-21-7-7858
This thesis also deals with finite element modeling and lasers
urn.kb.se/resolve?urn=urn:nbn:se:kth:diva-121209
If you go into detail, you soon realize, that you HAVE to simplify, since very many parameters are actually temperature dependent : dx.doi.org/10.1103/PhysRevB.77.075133
best regards,
Henning Hollermann
I may add a few references, that may be used to tackle this problem: Since the Verburg model yields (at least for me) a very unstable model, I would not recommend that as a start. The thesis of Dold was already mentioned: http://dx.doi.org/10.3929/ethz-a-010114797 Also www.comsol.de/model/laser-heat...g-a-self-guided-tutorial-12317 may be useful to you. You may have a look at the numerous papers there are for laser-induced damage in glass (SiO2), using a sub-bandgap high intense laser, e.g. Sun et al. http://www.opticsinfobase.org/oe/abstract.cfm?uri=oe-21-7-7858 This thesis also deals with finite element modeling and lasers http://urn.kb.se/resolve?urn=urn:nbn:se:kth:diva-121209 If you go into detail, you soon realize, that you HAVE to simplify, since very many parameters are actually temperature dependent : http://dx.doi.org/10.1103/PhysRevB.77.075133 best regards, Henning Hollermann
Posted: 10 years ago 20 apr 2015, 06:31 GMT-4
Dear Henning,
Thanks for your support.
How did you interface the two Coupled PDEs in TTM ?
I am not able to interface these equations.
please help me to solve the problem.
thanks
kiran
Dear Henning, Thanks for your support. How did you interface the two Coupled PDEs in TTM ? I am not able to interface these equations. please help me to solve the problem. thanks kiran
Posted: 10 years ago 20 apr 2015, 08:17 GMT-4
Dear Henning,
thanks
kiran
Hello kiran,
In general, you would have to introduce some input energy (intensity of the laser beam I(t)), a heat equation for the electrons (energy source from the laser) and a second heat equation for the lattice (energy source from electron-phonon-coupling) which would give you the lattice temperature. As source term for the second heat equation, you generally use some coupling function, which depends on the electron temperature usually (simple case)
Q_lattice = G*( T_electron - T_lattice ).
with material dependent electron phonon coupling constant G.
best regards,
Henning
[QUOTE] Dear Henning, Thanks for your support. How did you interface the two Coupled PDEs in TTM ? I am not able to interface these equations. please help me to solve the problem. thanks kiran [/QUOTE] Hello kiran, In general, you would have to introduce some input energy (intensity of the laser beam I(t)), a heat equation for the electrons (energy source from the laser) and a second heat equation for the lattice (energy source from electron-phonon-coupling) which would give you the lattice temperature. As source term for the second heat equation, you generally use some coupling function, which depends on the electron temperature usually (simple case) Q_lattice = G*( T_electron - T_lattice ). with material dependent electron phonon coupling constant G. best regards, Henning
Posted: 9 years ago 20 lug 2015, 05:43 GMT-4
Dear Henning,
I need to simulate the ultra-short pulse laser interaction model. (time step: 100e-15)
can i run this model in laptop or i need a workstation to run the model.
can you suggest me the system configuration to run my model.
thanks
kiran
Dear Henning, Thanks for your support. I need to simulate the ultra-short pulse laser interaction model. (time step: 100e-15) can i run this model in laptop or i need a workstation to run the model. can you suggest me the system configuration to run my model. thanks kiran
Posted: 9 years ago 20 lug 2015, 08:01 GMT-4
I use a powerful workstation, but I experience, that if you stick to lower dimensions than 3D (e.g. 2D axisymmetrical), it should be fine.
Why not just try it?
You may experience a very unstable simulation (difficult to reach convergence criteria), but this is not due to calculation power.
Henning
I use a powerful workstation, but I experience, that if you stick to lower dimensions than 3D (e.g. 2D axisymmetrical), it should be fine. Why not just try it? You may experience a very unstable simulation (difficult to reach convergence criteria), but this is not due to calculation power. Best, Henning
Posted: 9 years ago 20 lug 2015, 08:06 GMT-4
Dear Henning,
Thanking you very much
Dear Henning, Thanking you very much
Walter Frei COMSOL Employee
Posted: 9 years ago 20 lug 2015, 13:31 GMT-4
Hello Henning,
One new thing you may be interested in with version 5.1 (released in April) is the "Local Thermal Non-Equilibrium Multiphysics Interface" available within the Heat Transfer Module. Although it was designed to simulate heat transfer in porous media on the macro scale, where the temperatures in the porous matrix and the fluid are not in equilibrium, it would likely be quite easy to adapt this interface for your modeling needs. This interface solves for two temperature fields, and there is a pre-built coupling between the two.
Best Regards,
Hello Henning, One new thing you may be interested in with version 5.1 (released in April) is the "Local Thermal Non-Equilibrium Multiphysics Interface" available within the Heat Transfer Module. Although it was designed to simulate heat transfer in porous media on the macro scale, where the temperatures in the porous matrix and the fluid are not in equilibrium, it would likely be quite easy to adapt this interface for your modeling needs. This interface solves for two temperature fields, and there is a pre-built coupling between the two. Best Regards,
Posted: 9 years ago 4 apr 2016, 21:30 GMT-4
Dear Henning:
Could you share your model with me ?
Thank you for your kind consideration of this request.
Thanks for your help! Email:lin_qing2008@126.com
Best wishes!
Qing
Dear Henning: Could you share your model with me ? Thank you for your kind consideration of this request. Thanks for your help! Email:lin_qing2008@126.com Best wishes! Qing
Posted: 9 years ago 27 mag 2016, 23:30 GMT-4
Anybody tried two-temperature-model (electronic/lattice) for fast laser-excitation with 5.1 version?
Hi, Anybody tried two-temperature-model (electronic/lattice) for fast laser-excitation with 5.1 version?
Posted: 8 years ago 28 mag 2016, 03:45 GMT-4
Anybody worked with "Local Thermal Non-Equilibrium Multiphysics Interface" in 5.1 version? I wish to see the two-temperature-model (electronic/lattice) for fast laser-excitation of a thinfilm.
Hi, Anybody worked with "Local Thermal Non-Equilibrium Multiphysics Interface" in 5.1 version? I wish to see the two-temperature-model (electronic/lattice) for fast laser-excitation of a thinfilm.
Posted: 7 years ago 8 set 2017, 05:35 GMT-4
Updated: 7 years ago 22 set 2017, 05:48 GMT-4
Hi I was trying to implement TTM with the multiphysics called local thermal non equilibrium. The module is working . But how the equations given in heat transfer in solids and fluids related to LTNE multiphysics I did not understand.
Thank you
Hi I was trying to implement TTM with the multiphysics called local thermal non equilibrium. The module is working . But how the equations given in heat transfer in solids and fluids related to LTNE multiphysics I did not understand. Thank you
Posted: 7 years ago 29 set 2017, 05:31 GMT-4
Hi, I was also trying to implement TTM to predict ablation in thin film. However, one thing I don't understand is how to removel the material in thin films which would definately change the thermal condition during the process. Is LTNE helpful?
Posted: 7 years ago 29 set 2017, 09:40 GMT-4
Updated: 7 years ago 29 set 2017, 09:41 GMT-4
Hello Tong,
If you're wanting to model material removal, you may also find this article helpful: https://www.comsol.com/blogs/modeling-thermal-ablation-for-material-removal/
Best Regards,
Hello Tong, If you're wanting to model material removal, you may also find this article helpful: https://www.comsol.com/blogs/modeling-thermal-ablation-for-material-removal/ Best Regards,
Posted: 7 years ago 14 feb 2018, 13:57 GMT-5
I am trying right now to implement a e-p thermal coupling in a solid throught the LTNE physics. So far I haven't manage to go through since I want to set the coupling between two solids and not a solid and a fluid.
The problem is that when I set up a "solid" node in the "Heat transfer in Fluid" physics, all the domains in "domain selection" of LTNE are set as "non applicable".
I gonna contact Comsol and let you know the answer if I have one.
Hello, I am trying right now to implement a e-p thermal coupling in a solid throught the LTNE physics. So far I haven't manage to go through since I want to set the coupling between two solids and not a solid and a fluid. The problem is that when I set up a "solid" node in the "Heat transfer in Fluid" physics, all the domains in "domain selection" of LTNE are set as "non applicable". I gonna contact Comsol and let you know the answer if I have one.
