problem with solving two coupled equations
I have to solve two coupled pde equations depends mutually. I have given these equations as follows
1)
∂T/∂t+∇∙(-c*∇T)=∅1(T)*∂u/∂t ;
where c =constant, and 1 initial condition (T at (t=0)=308K) and then 4 boundary conditions and BCs are
(at r=0, ∂T/∂r=0 or insulated; at r=r_outer, c*∂T/∂r=-h_out*(308-T);
at z=0,c*∂T/∂z=-h_(out*) (308-T); at z=L,c*∂T/∂z=-h_out*(308-T); )
Which is given by the following steps “add physics>> mathematics >> classical PDEs>> heat equation”
given the coefficients and source term according to the requirements.
2)
∂u/∂t=k_so*exp(E/(R*T))*(f(T)-u)
with initial condition (∂u/∂t)at t=0 = 0.0001 which is given by the steps “ mathematics>> pde interfaces >> general form pde (g)” and given the coefficients and source term according to the requirements
But error is showing that
failed to evaluate variable.
- Variable: comp1.u
- Geometry: 1
- Domain: 1
- Expression: d(d((-(comp1.Tt-comp1.S*comp1.delt_H*pd(comp1.u,t))*test(comp1.T)-0.2812*comp1.Tr*test(comp1.Tr)-0.2812*comp1.Tz*test(comp1.Tz))*(dvol),{test@0}),co
What should I do? Anyone please help….
1 Reply Last Post 6 nov 2014, 11:06 GMT-5
Posted: 1 decade ago 6 nov 2014, 11:06 GMT-5
hello sir i have same problem
i desgined comsol model to solve these two coupled partial equation,but not getting correct results
du1/dx=-1.148*u1-4.462*u1*u2-3.8*10^-12*u1^2-1.9*10^-22*u1^3-6.83*10^-22*u2*u1^2-2.36*10^-22*u1*u2^2.........(1)
du2/dx=-1.148*u2+50*u1*u2-4.93*10^-12*u2^2-3.41*10^-23*u2^3-2.44*10^-23*u2*u1^2-11.17*10^-23*u1*u2^2........(2)
initial conditions
u1(0)=1,u2(0)=.01
i simulated the model as
1D>mathematics>pde inteface>general form pde>dependent variable=2>preset studies>stationary>finish
then put both equation and boundary condition,please tell me process is correct or not,if any other method tell me
thank you
hello sir i have same problem i desgined comsol model to solve these two coupled partial equation,but not getting correct results du1/dx=-1.148*u1-4.462*u1*u2-3.8*10^-12*u1^2-1.9*10^-22*u1^3-6.83*10^-22*u2*u1^2-2.36*10^-22*u1*u2^2.........(1) du2/dx=-1.148*u2+50*u1*u2-4.93*10^-12*u2^2-3.41*10^-23*u2^3-2.44*10^-23*u2*u1^2-11.17*10^-23*u1*u2^2........(2) initial conditions u1(0)=1,u2(0)=.01 i simulated the model as 1D>mathematics>pde inteface>general form pde>dependent variable=2>preset studies>stationary>finish then put both equation and boundary condition,please tell me process is correct or not,if any other method tell me thank you
