inverted mesh element near coordinate
Hi dear all
I want to see the mechanical changes due to flow of current through two parallel wires in COMSOL. To do this, first I used two "magnetic field" and "solid mechanic" modules. After getting the results I noticed there is no filed change resulted by mechanical changes which happens due to magnetic forces. After reading previous discussion, I used "moving mesh" module to execute the changes. But then I faced this error:
"inverted mesh element near coordinate"
What I have to do in order to solve the error?
I used this terms in my modeling:
1)free deformed(for all domain, 2-wire and air)
2)prescribe mesh displacement(just for boundary of wire )
With best thanks and regards
1 Reply Last Post 27 apr 2016, 10:09 GMT-4
Hello Reza Kadkhodaee
Posted: 9 years ago 27 apr 2016, 10:09 GMT-4
Hi Reza,
I have exactly the same problem although I used the prescribed deformation in all domain instead of free deformation but I think that it's the same thing. However, have you solved your problem??
Thanks a lot
Simona
Hi Reza, I have exactly the same problem although I used the prescribed deformation in all domain instead of free deformation but I think that it's the same thing. However, have you solved your problem?? Thanks a lot Simona
