Voulme integral of magnetic flux density
Hi everyone
How can I perform a volume integral of the magnetic flux density (Bx, By or Bz) ?
Does the "Subdomain Integration" perform that?!
Thanks a lot
1 Reply Last Post 5 giu 2010, 06:28 GMT-4
Posted: 1 decade ago 5 giu 2010, 06:28 GMT-4
the cubdomain integration is ther to integrate any value you put in, the default predefined ones or any valid equation you decide to build upon these.
Its the same for boundary and edge integration, w.r.t. respective dimansional values.
just note that 2D axi requires a 2*pi*r in v3.5 to go from edge to surface integration, erspective surface to volume, while in V4 the 2*pi is already included, pls check carefully, as v4 is still slightly evolving ;)
Have fun Comsoling
Hi the cubdomain integration is ther to integrate any value you put in, the default predefined ones or any valid equation you decide to build upon these. Its the same for boundary and edge integration, w.r.t. respective dimansional values. just note that 2D axi requires a 2*pi*r in v3.5 to go from edge to surface integration, erspective surface to volume, while in V4 the 2*pi is already included, pls check carefully, as v4 is still slightly evolving ;) Have fun Comsoling Ivar
